Hi Everyone ,
in ax 2009 i am installed reporting extensions and after that i deploying standard reports i am getting error below
0827.report server error.docx (257 KB)
Thanks for advance
Hi Everyone ,
Thanks for advance
Hi Naveen,
Do you have administration rights for your login user. i.e., RAMPGROUP\naveen.kumar.
plz check this and let me know.
Raman Kutala.
Hi Naveen,
I think it is EP issue, you can do the product configuration, i hope it will work for you.
Plz perform the product configuration once again.
but till now i didn’t install EP in my system
If you are not installed EP, so, what is this database “SharePoint_Config23”.
Check in you Database an dplz let me know which version of SQL you are using.
Check in you Database and plz let me know which version of SQL you are using.
Hi ,
Just now i checked again same error in report deployment ,but event log doesn’t showing error message.
Just Delete “SharePoint_Config23” database and try again.
