In a Report I have some sections that are printed when some conditions are true.
But even if one section is not printed, the space keeped for is used in the report layout. So sometimes I have empty spaces in my report, and this is not good.
How can I say to my report that if section condition is not true, do not keep that report section empty in finaly report layout???
Maybe something is missing im my report sections propertyes.
I have pageloop footer 5, pageloop footer 6, pageloop footer 7, pageloop footer 8.
pageloop footer 5 is always printed, and then pageloop footer 6 or pageloop footer 7. If pageloop footer 6 is not printed, I have a space between pageloop footer 5 and pageloop footer 7. Why???
This doesn not hapend in Headers. Is it related with footer section?
Oh, then change Keep With Next property to No, in one of my report i was facing the same problem when i was having many footers… it works for me… try for you too…!!!
your assertion is only partially true - header, groupheader, transheader and body sections don’t take any space when they are not printed, but footer and groupfooter section do. I think that this is because of the fact that navision cannot tell in advance whether a footer or groupfooter section will occur, so it keeps the needed space available just in case…
And Luana is right, sometimes this may be really annoying.
A way to avoid to use footer sections, is to add a section based on the integer table just after the dataitem to which the footer section would belong, at the same level, and print your “footer” as a body section in the new dataitem…
Groupfooter section are more tricky, but something may be cooked up too. [:)]
The problem is this happening in PageLoop footer Section. I have 4 PageLoop footer.
I have pageloop footer 5, pageloop footer 6, pageloop footer 7 and pageloop footer 8.
pageloop footer 5 is always printed, and then pageloop footer 6 or pageloop footer 7. If pageloop footer 6 is not printed, I have a space between pageloop footer 5 and pageloop footer 7. The space for pageloop footer 6 is empty on my report
