cyclem
September 7, 2012, 3:59pm
1
I am new here.
This is my first question.[:)]
I am making a report where I show sales invoice lines.
I need to show all lines from sales invoce except lines that have “Internal Correction” equal 1.This value is in Sales Invoce Header.
I don’t know how to filter this. This is easy in SQL where I can use INNER JOIN.
Can someone help me with this.
jspopp
September 7, 2012, 10:05pm
2
Hi, try something like this and put it in the OnAfterGetRecord trigger:
IF SIH.GET(“Sales Invoice Line”.“Document No.”) THEN
IF SIH.“Internal Connection” = 1 THEN
CurrReport.SKIP;
Enter SIH record Sales Invoice Header into your global variables
Run the report through your debugger and see if this gets the results you are looking for. Good luck with it!
What are the dataitems you have in report?
If you have Sales Invoice Header also then directly pUt the filter in DataItemTableView
cyclem
September 8, 2012, 8:25am
4
I have only one dataitem(Sales Invoice Line).
cyclem
September 8, 2012, 8:40am
5
I tried to like you told me but I got this error “You have specified an unknown variable Internal Correction”.
I entered SIH record into global variables.
Can you give me more advice.
Thank you.
Where is the field ‘Internal Connection’ available in Table?
Sales Invoice Header or Sales Invoice Line ?
cyclem
September 9, 2012, 11:34am
7
The name of field is “Internal Correction” and it is present in table Sales Invoice Header.
Where did you write code to get the Sales Invoice Header?
Can you show us the code?
jspopp
September 10, 2012, 5:08pm
9
Hi, did you try to use the code I mentioned above? Use the C/AL Symbol Menu (F5) to find the field you need. Make sure you use the field name and not the caption. Note, in my code above, I mistyped ‘correction’ with ‘connection’. I hope this helps!
cyclem
September 10, 2012, 6:24pm
10
That helped me. At the first time i just copied your code.
Thank you very much.[:)]
jspopp
September 10, 2012, 6:31pm
11
Nice! thanks for letting us know
