I have built a simple report but for some reason it repeats the fields 3 times then moves on and does it again. Any idea why that would be?
Which NAV version are you using?
With RDLC report definition (NAV 2013 onwards) if you have different tables the dataset generated is the Cartesian product of all the record, and you have to manage appropriate line filters inside Visual Studio to avoid lines to be repeated.
Well I am not using different tables but I will check filtering just to be sure that isnt the case, I am only using “Sales Invoice Line” table.
