I want to show some text for each different account number (in the picture they are green) once. The text is everytime the same text (an instruction about things to keep in mind)
but this looks to me like a waste of space (in page 1 and 3).
instead of this, I want to show the text “in the header” or at least at the same height as the logo like shown here:
(As is wrote: it is everytime the same text, but because it is much bigger than the logo I want it to show it only once for each different account number)
But if I put this text in the header it leads to the occurrence on every single page. And I want it to show it just for each different Account Number (in my first picture in green) and not on every page
hi ,
have you Tried like Keeping In Group Header and Hide that text box, then in Header create a text box in expression write like
ReportItems!Textboxyouhavecreatedintable.value
I am struggling to adapt your solution for the image/logo as well, but I don’t have a clue. The image messes the tablesize everytime up so I just can’t put it in the table - and even if I could, I wouldn’t know how to show an image in header referring to a field in the body.
Try This
the basic is First in Onafter get record make sure the picture calculated
like Companyinfo.calcfield(picture);
Now coming to report layout. As i Suggested take separate textbox for picture which as usually hidden
in expression writelike below
= Convert.ToBase64String(Fields!picture.value)
then Now in header Take a rectangle then Insert a Image in Rectangle
in image Properties
Select Image Source As = Database
Use This Field = Convert.FromBase64String(ReportItems!PictureTextbox.value)
Use this MIME type = img/bmp
