Report Permission Error
Hello All,
I am trying to create simple report in NAV 2009 Classic, when try to save report it gives me following error:
You don’t have permission to create report. Please contact your administrator.
My NAV Server and User configuration is as below:
  1. NAV Server is running under windows domain account.
  2. That user has SUPER permission role.
  3. Report Ojbect ID between 50000 - 50009
  4. My License have - 7,110 Report & Dataport Designer
I am not able to solve this issue. Can anybody help me out.
Regards.
Hi Asim,
Are you doing this on a local database? Or on a server?
Make sure that your license has been imported correctly.
Hi Erik,
I have NAV Server on one machine and Database is on another machine (SQL Server 2005).
I have imported license file in NAV Classic, I also saved that license to Database using Alter Database option.
Regards.
Hi Asim,
Welcome to the Dynamics User Group !
Has the user just the SUPER role ?
If so you will need to add the ALL role
Hi Dave,
Thank You.
As per your suggestion I changed the Role to ALL of my domain window user, but while changing this I am getting error like
You dont have permission on Table 0.
After that I change my login and logged in using database user (SA) and changed the Role of db user(sa) to ALL and now I am able to save my first report. [:)]
Thank you very much. Can you please tell me why windows user causing problem.
Regards.
Hi Asim,
Glad to help [:D]
Note - you should have both SUPER & ALL role or for full permissions SUPER & SUPER (DATA)
Check the SQL permission for your windows login on the SQL database. Also have you run a Synchronize on the Single/All users?
Hi Dave,
I have created domain user account on SQL Server and given db_owner and db_securityadmin permission on Demo Database NAV (6).
I also synchronize all users.
I also have problem regarding Role Tailored Client connection to server using windows domain account , for which I have just posted another query on this forum.
Also done Object Change Listener process.
Regards.
This is an overkill - normally you don’t need any of the above, especially the second one, as db_owner is the highest possible for given database…
