Report of scraps in quarantine order
Hello
We had produced an item and this item was gone to quarantine . We did a test it by quality order and the result of this test was fail. so we must scraped it in quarantine order . Now we want to track and find the trace and get report of this scrap (physical or financial) in Dynamics AX 2009 ?
Thanks a lot
Hi
If the Item got failed, reject the same in quarantine and move it to rejection warehouse. Create Return Order, Invoice it and return back to supplier. By this you can have both Physical and Financial entries in the ledgers.
You can also check the following links which will be helpful.
http://dynamicsuser.net/forums/t/26283.aspx
http://dynamicsuser.net/forums/p/47073/275240.aspx#275240
Prabu
Hi Prabu
Thanks for answer but my item is production and it inter in quarantine by report as finish in production order.
Hope the below link may help you.
http://dynamicsuser.net/forums/p/53212/278188.aspx
Prabu
