Report nav 2013
Hi all
I would ask You one question.
I have upgrade NAV 2013 to NAV 2013 R2 and since then I noticed some strange behavior when I work with reports.
In the header of report I have textbox, and if I don’t left empty space between Report Header and Report Body (after the text box), then when I print it cuts text box.
if I left empty space between Report Header and Report Body (after the text box), then prints ok, but I need that space and I can’t left it.
Padding,size…of textbox are ok so that is not the reason for that behavior.
In addition I attach a picture to see more precisely.
I am using VS 2012
(before R2 I don’t have this kind of problem)
Is there a way to be solved this.
Thanks In advance
And here is how looks with space:
And this is the way how should look
