Report Limitations
I am attempting to put 235 fields on a report but seem to hit a limit in the report length(top-to-bottom). I’ve been able to solve the problem,I thought, by using Integer sections; but, this seems to be limited as well. I have only 1 smaller section to go but cannot view it. The scroll bar will not continue any further and I have tried the page down and line down with no success. Any suggestions anyone? Using version 4.00 with patch.
Citazione:
Originariamente inviato da jgyonce - 2004 Dec 27 : 20:32:25
You should have been able to add the section, which is the trickiest part of the job. Now, beside redesign the report thoroughly, your only option is to export it in text form, work on it with a common text editor then try to reimport it. Not an easy task, but feasible. [8D] Good luck Anna
Navision has this strange kind of limitation that the scroll bars don’t work if the report exceeds a certain limit, and the only solution is to “edit” the report in notepad or some other editor. But why don’t you try another approach… why not filling your 235 field values in a temporary table, with some kind of generic datatype like code or text, and then printing this temporary table. Depending on your report, this might be easier and if you need to add another 5 fields it might be easiert then editing in text mode… Saludos Nils
