Report - Landscape
Hi There I have prepared a report but I am not able to print the report as landscape. Where can I choose the setting? Thanks in advance
When you design the Report and are in Report Designer, select the new, empty line below the last DataItem. Then go into Properties and look for the Orientation option. Save the Report and that should be it.
Thanks Nlson. Its done.
