Hi all…
I designed one report (Pallet tag) with barcode and it is coming fine. But the problem is that bar code cannot be read.
I am using DAX 2009 with SP1+Hotfix1 and I set the bar code font ‘BC C128 HD Wide and BC C39 3 to 1 HD Wide ‘ (with the size of 12/24/38/44) in item master barcode setup and also same as in report But Item barcode is not scanning by reader.
My report size is 100x70mm and I can read the same barcode(Same barcode with same font and size) of the item from third party bard code designer software
How I can solve this issues?.
