I have done a report with programable sections.
in one programable section we have records.
according to ther records the structure is changing.
how can i make this one static.
Thanks in advance
Sunil
Thanks in advance
Sunil
Hi Sunil,
what you want make static
you are adding any control in the runtime…
in the report programable section i have controls.
acording to the more lines structure is changing.
how can make this static.I mean to say if 3 record report structure is ok…
if it goes more than 3 lines bottom section and programable section wr the fields are there that section is expandin.
Hi Sunil,
What my understanding from u saying is
Means you want fix the data(no of lines) in the programmable section…
If you want to fix the number of lines
then first thing u decide is how many lines you want fix.
For example: you want to fix 3 lines
take a counter variable and increment everytime
check the condition that
if(CounterVariable == 4)
element.newpage();
counterVariable = 0;
thanks for your info,
But my requirement is the programable section is hight is increasing and decresing according to ther lines…
according to I can restric the lines…
but even though the hight of section is changing any solution for this…can i fix the progra section hight.
Thanks in advance
sunil
there is a property ‘Height’ for the ‘programmable section’…try with it …
