In BC SaaS, I am running a customize report after Bank Reco posting and saving it to a drive.
But now what issue I am facing is,
in preview and pdf saved manually from preview is giving all values.
but the pdf saved by code is giving some values and some are missing.
- this is report preview
- manually saved pdf from preview
- pdf saved by code
Code written for saving pdf is below.
BankNo := Rec.“Bank Account No.”;
StatementNo := Rec.“Statement No.”;
StatementDate := Rec.“Statement Date”;
LastStatementBal := Rec.“Balance Last Statement”;
StatementEndBal := Rec.“Statement Ending Balance”;
BankAccReconPost_Yes_No_CU.RUN(Rec);
BankAcReconclLine.SetRange(“Bank Account No.”, BankNo);
BankAcReconclLine.SETRANGE(“Statement No.”, StatementNo);
BankReco.SETTABLEVIEW(BankAcReconclLine);
BankReco.GetInput(BankNo, StatementNo, StatementDate, LastStatementBal, StatementEndBal);
BankReco.RUN;
FileName := 'E:\Bank Reco Statement of ’ + BankNo + StatementNo + ‘.pdf’;
TempBlob.CreateOutStream(BlobOutStream, TEXTENCODING::UTF8);
RecRef.GetTable(BankAcReconclLine);
Report.SaveAs(50000, ‘’, ReportFormat::Pdf, BlobOutStream, RecRef);
FileMgt.BLOBExport(TempBlob, FileName, true);
Code saving the report in pdf but some values are not coming.
The values which are not coming all are in header.
Can someone help me or guide me where I am doing wrong? Where is code going wrong? or is it a layout issue?
Thanks in advance.
