I have a report to display data of a selected PurchLine in PurchTable Form.
From PurchTable Form after selecting a PurchLine (form Lines) by clicking a Button (CommandButton) this report will open.
The same after clickng a CommandButton i want to open the same report for the selected Production Order from ProdTable Form…?
Share your Suggestions…
Thanks In Advance…[:)]
What exactly are you trying to achieve?
Vinay
I have a Report created using PurchLine DataSource.
Now i want to link that report to ProdTable Form
It should display data of the selected Production Order ( Means Selected ProdID )
Coz we have ProdTable.ProdId = PurchLine.InventRefId
You can create a menuItembutton(calls the report) on the ProdTable form and set the data source as ProdTable.Now you can receive the record in the report init() method using following code
ProdTable prodTableObj;
prodTableObj=element.args().record();
After receiving the record you can fetch any value of ProdTable record.
Vinay
