Report display method
I have a problem with displaying a specific field in the report (body section). Let’s assume that I have the following records in the table:
String1
String2
String3
I would like to display instead of “String1” just 1. Could you give me an advice how should I do it?
Thank you.
Hi Paul ,
Can u pls elaborate your Question .
“I would like to display instead of “String1” just 1.” Pls give with one Example …
We have a field CollectionLetterCode in the CustCollectionLetterTrans table. For example we could have three transactions and each of them has a different CollectionLetterCode.
CollectionLetter1
CollectionLetter2
CollectionLetter3
What I would like to display on the report is just “1” not “CollectionLetter1”. So I can not use the field from the table. I want to create a method that will display it.
Hi Paul,
you can create a display method like this
display str yourmethod()
str yourStr;
yourStr = surSrt( CollectionLetter1, (strlen(CollectionLetter1) -1), 1); // will get only “1” from here
return yourStr;
thanks
Manish
Hi Paul,
Try this logic
display str methodName()
str s, s1;
int len, i;
s = “CollectionLetter1”;
len = strlen(s);
for (i=1; i<=len; i++)
if (global::isInteger(substr(s,i,1)))
s1 = s1 + substr(s,i,1);
return s1;
