I have done a report which is printing.but the font size is very small.
In which level property i need to change.I tried with design level property.
Hi shashank You just select your controls in Report Design and in properties increase font size…
Hi Shashank,
Sometimes if you have more no.of fields in report the font size will be reduced to adjust all fields into single page… check ur report in that way also and finally.
You can change FontSize of a control by thier “FontSize Property”
