How could I possibly access a control on report section, to change the property blank zero depending on the value of the headers. I have about Hunderd columns: Sorted in Descending order. Once an header reads Zero the body will not show for the column; However for any header greater than Zero I want the rows to show even though the value is zero. If I have to use section rule I will have to define Hundred rows and code such. Also how can I remove the Category header if the body has no value. Adewale A. Abiola
Hi Adewale, it is not possible to change during runtime this property [V] What you can do is to define an additional section and depending on the value of the headers add a SHOWOUTPUT(condition) in the OnPreSection-trigger of each section and show one of the two sections depending your needs. Saludos Nils
