Report body section looping?
Hi There,
Could anybody help me on how to restrain report body section?. coz its keep on looping. I only want to display the current record form in the report. [:)]
Thank You,
Ronnel
report body loops only when you hav used an Integer Tableā€¦have you?
Give more detail please Ronnel.
All the best[Y]
Not true.
Hi Ronnel,
Report body loops based on the dataitem record you have selected. To control this you use the DataItemTableView property of the dataitem or set a filter on the record the dataitem is based. If you need to loop a report with is not based on an actual table then the virtual table Integer is used. The property and filters can be set as per a normal table.
