Please how to customize the background image of a report and fit it to the page
Thanks.
Thanks.
Which version of Navision you are using ??
Is it classic or RTC client ???
NAV 2013
NAV 2013 CLASSIC CLIENT
By clicking on the report page (Page header, body or page footer ), on your right hand side you will be able to see the properties “FILL”. Go through it and choose the preferred way of putting the image there (External, Database and Embedded). Remember the image you are using should be the same as of your page otherwise it will be cropped.
Regards:
Gaurav Singh
There is no classic client for NAV 2013 .it is only have RTC client and development environment opens in classic.
Well said Amol Sir. Anyhow I managed to understand the query of Lorisse and i replied accordingly.
Hi Gaurav,
Hi Naveen,
Did you get an answer to your question? Did it help you? The members and moderators here on DUG use our spare time and help you for free, all we ask in return is that you spent a few seconds to let us know if we helped you solve your problem.
If any of the suggestions helped you solve your question/problem, then please click the “Verify Solution” on the answer that helped you, so that we can see that your problem is now “resolved”. Otherwise let us know how if there is something else you like to know.
Have a nice day! [:)]
Another question without any marked solutions. There is an article on how to edit image in NAV 2013, hope it can solve your image processing issue. If it helps you a little. Please mark it as a solution, thank you.
http://msdn.microsoft.com/en-us/library/ms251715(v=vs.90).aspx
