Replica DB Axapta
Hi
i need to replicate some tables in AXAPTA DB. I would be use the replica feature’s SQL Server 2005 with Publisher - Subscriber architectures, precisely the MERGE option. This option add a column type ROWGUIDCOL and my question is:
this column can impact to transfer data from AXAPTA application layers and AXAPTA DB layers?
My AXAPTA version is 4.0.
Thanks in advance for your answer.
Bye
Enrico
Hi Enrico and welcome to forum!
However, be careful further on, when posting your question, please select AX forum if question is AX related… I moved your post.
Moderator
Sorry … i’m new!!
thanks you for moving the post
Hi
can you tell me in wich do you have move my post?
Thanks in advance
Bye
I can’t found my post … can you tell me where can i found it?
