repetition of data in report
Hi, For getting work centre wise consumption of items i have done the following things but the data in the report is getting repeated in the report.
Used three data Items
  1. Item Ledger Entry 2) Prod. Order Component 3) Prod. Order Routing Line
wITH INDENTED BENEATH ONE ANOTHER in the same order .
But the data in the Prod. Order Component is getting repeated/
Why iam getting this error.
I think you have discussed similar thing already, perhaps you should follow up it in the same post.
Anyway, the order of the tables chosen is not correct.
What is the status of your Routing Link Code issue?
