Rename Item-No at runtime
Is it possible to rename the Item-No at run- time and how? I’ve tried, but got message “item…can’t found” when I came to codeline Art.Modify… What I want is change for example Item-NO: 70000 to Item-NO 70000U at runtime, because there is a lot I want to change.
hi, if the item numbers that u want to change are the primary key of the table then you need to use the Rename command and not the Modify command, you can read the syntax of Rename in the Help provided hope this will be of help, take care regards Vishal
Yes, it works…thanks a lot
ur welcome. regards Vishal
