Rename item dimension
Hello All,
How can i rename item dimension size to “Width” and colour to “pattern”.
Please help me urgent.
  1. Click > > > .
  2. Go to the table.
  3. Select the dimension to rename. Only the size and color dimensions can be renamed.
  4. Go to the tab and then click .
  5. In the field, change the language of the dimension texts if needed.
  6. Change the text in the fields as needed. A check mark will appear in the field if the dimension text has been changed. The field at the bottom of the form displays the original texts.
