Hi Everybody
I want rename Code (FA). I create 1 table name FA_Temp with 2 filed (FA Old, FA New). I create 1 report and write code rename Code FA on table Fix Asset (ID 5600). But it’s not work.
Fixed Asset - OnAfterGetRecord()
IF FA_Temp.GET("No.") THEN BEGIN
CodeFA:=FA_Temp."FA New";
lRec_FixedAsset.RENAME(CodeFA);
END;
Please help me fix code. Thanks very much.
Do the following
In the existing fixed asset table add a new field called New Fixed asset no., Update all the new fixed asset no. via a dataport.
Create a new processing report with Integer with Maxiteration in property = 1
Declare a variable TempFixedAsset Data type Record Fixed Asset (Make sure you set this to temporary in properties)
Declare a variable FixedAsset Record FixedAsset
Declare another variable NewFixedAsset Record Fixedasset
OnAfterGetRecord
clear(tempfixedasset);
fixedasset.reset;
if fixedasset.find(’-’) then begin
repeat
tempfixedasset.init;
tempfixedasset.transferfields(fixedasset);
tempfixedasset.insert;
fixedasset.delete;
until fixedasset.next = 0
end;
if tempfixedasset.findset then begin
repeat
fixedasset.reset;
fixedasset.init;
fixedasset.transferfields(tempfixedasset);
fixedasset.“no.” := tempfixedasset.“new fixed asset no.”;
fixedasset.insert;
until tempfixedasset.next = 0
end;
Thanks sbhatbng reply.
I have a question ? Can get new code form table created.
Sample :
- Table (New FA)
1 Field : FAold
2 Field : FANew
→ variable TablenewFA
SETRANGE(TablenewFA.FAOld, “Fixed Asset”.“No.”)
I want get data form table New to Table “Fixed Asset”
Thanks very much.
sbhatbng, I follow your instructions. But it does not work
Declare a variable TempFixedAsset Data type Record Fixed Asset (Make sure you set this to temporary =Yes in properties)
Declare a variable FixedAsset Data type Record “Fixed Asset”
Declare another variable NewFixedAsset Data type Record “Fixed Asset”
CLEAR(TempFixedAsset);
FixedAsset.RESET;
IF FixedAsset.FIND('-') THEN BEGIN
REPEAT
TempFixedAsset.INIT;
TempFixedAsset.TRANSFERFIELDS(FixedAsset);
TempFixedAsset.INSERT;
FixedAsset.DELETE;
UNTIL FixedAsset.NEXT = 0
END;
IF TempFixedAsset.FINDSET THEN BEGIN
REPEAT
FixedAsset.RESET;
FixedAsset.INIT;
FixedAsset.TRANSFERFIELDS(TempFixedAsset);
FixedAsset."No." := TempFixedAsset.NewCode;
FixedAsset.INSERT;
UNTIL TempFixedAsset.NEXT = 0
END;
If you have 2 separate tables then you can use setrange and then get the No. and then insert the new no. while creating the Fixed Asset record.
