removing of home menu
hi all,
is it possible to remove the home menu from the navigation pane
thanks in advance
We cannot move, rename, or remove the Home button. It is always the first button in your navigation pane.
Why do you need this?
You cannot rename and move the home button. However, you can move, rename, or remove other menu buttons in your navigation pane.
