Remove NAV 2013 Default Instance
Hello,
I would like to delete a NAV 2013 instance from the console. I have several instances on my computer.
When i try to delete an instance named DynamicsNAV70 i got the following message :“Unable to remove the ServerSettings or ServerInstance used by the default instance”.
How can i delete this instance : can i use the sc delete command ? Is there any risk of doing that ?
Thank you in advance for your help.
In NAV 2013 deleting the default instances means deleting all other instances as they are just sub-instances. So if you don’t need the default instance then you can either rename it or disable it.
Thank you for your answer.
Best regards
