I’m opening ax for automation purpose. When opening from configuration file, I’m calling the synchronization. But when opening now, it is stopping in credential part. Once we give / close the window then it is automatically starting the sync and further steps.
How can I avoid this login window / remove this ? pls suggest.
It’s this related to a remote app connection rather than the AX client?
I think it is Ax client only.
Hi Martin,
I’m expecting like while opening the configuration file , I have to pass the credential from that or in ax somewhere before opening that login window, I have to disable it.
Is it possible ?
Pls advise if you have idea .
