You mean to make undo purchase receipt? If remaining amount is 0, it means the outbound entry(s) is posted or you had negative sales before posted. May You
Can try to revise the applied entries with your recent purchase (41555) using the item entry application function then make undo. Be mind your item cost will be revised too.
