Release date
Hi ,
what is the use of the release date in journals ?( with out entering the this date in the journals i could able to post the journals ) , then what is the importance of this date ?
Can you please elaborate on which journal you are facing this issue?
Pranav…
Thank you for the reply.
I am not facing any issue during posting of journal with out entering the Release date . Just i would like to know what is the use of the Release date which is availble in all financial journals .
Hi Lally,
Release date is basically used to hold the journal for posting, the journal cannot be posted before that date.
For instance, on 11/02 you create a journal and you want to post it after 11/03. In this case specify release date as 11/03.
User won’t be able to post it on 11/02. This is the use of release date.
Pranav…
