Relation between Serial # and PO #
What is the relation between serial number for particular item and purchase order.
how do we get details of PO# from serial number of an item?
Raj
Find InventDim corresponding to the serial number. Find PO line by joining inventTrans, use inventDimId and InventTransType = Purch in where clause.
Raghav.
Hi Raj,
Can you be more specific on your query? on which aspect (technical or functional) your asking about this query?
From serial numbers you can find-out the Purchase order. If you go to serial numbers form Inventory management > Inquiries > Dimensions > Serial numbers. In the Serial numbers form select the particular serial number then click on Transactions button. It will show you the Transaction.
If your query is related more on something then be more clear on your query.
Sarathy
