I need this information for a packing slip and an invoice.
This job works for the Case 1
static void SAUInvoicedPO(Args _args)
Query query;
QueryRun qRun;
QueryBuildDatasource datasource;
VendInvoiceTrans vendInvoiceTrans;
VendInvoiceJour vendInvoiceJour;
PurchLine purchLine;
AccountingDistribution accountDistribution;
PurchTable purchTable;
//PurchTable
query = new Query();
datasource = query.addDataSource(tableNum(PurchTable));
//VendInvoiceJour
datasource = datasource.addDataSource(tableNum(VendInvoiceJour));
datasource.joinMode(JoinMode::InnerJoin);
datasource.relations(true);
datasource.addRange(fieldnum(VendInvoiceJour,PurchId)).value("=order0001");
datasource.addRange(fieldnum(VendInvoiceJour,InvoiceDate)).value(queryRange(19\4\2016,20\04\2016));
//VendInvoiceTrans
datasource = datasource.addDataSource(tableNum(VendInvoiceTrans));
//PurchLine
datasource = datasource.addDataSource(tableNum(PurchLine));
datasource.relations(false);
datasource.addLink(fieldNum(vendInvoiceTrans,PurchId), fieldNum(purchLine, PurchId));
datasource.addLink(fieldNum(vendInvoiceTrans, PurchaseLineLineNumber), fieldNum(purchLine,LineNumber));
//ACCOUNTINGDISTRIBUTION
datasource = datasource.addDataSource(tableNum(AccountingDistribution));
datasource.addLink(fieldNum(accountingDistribution, SOURCEDOCUMENTLINE), fieldNum(purchLine,SOURCEDOCUMENTLINE));
qRun = new QueryRun(query);
while(qRun.next())
vendInvoiceTrans = qRun.get(tablenum(VendInvoiceTrans));
vendInvoiceJour = qRun.get(tablenum(VendInvoiceJour));
purchLine = qRun.get(tablenum(PurchLine));
accountDistribution = qRun.get(tablenum(AccountingDistribution));
purchTable = qRun.get(tablenum(PurchTable));
info(strfmt(’%1 ,%2 , %3, %4 %5 , %6, %7 %8 %9 %10 %11’,vendInvoiceJour.LedgerVoucher,
vendInvoiceTrans.PurchID,
vendInvoiceJour.InvoiceId,
vendInvoiceTrans.ItemId,
vendInvoiceTrans.Qty,
vendInvoiceTrans.PurchUnit
,PurchLine.REMAINPURCHFINANCIAL,
PurchLine.REMAINPURCHPHYSICAL,
purchLine.RemainPurchFinancial
,purchTable.PurchName,
purchLine.PurchStatus
So i need do the some for Sales ORDER ,i tried this for the CASE 2 :
static void getCustInvoicedTrans(Args _args)
Query query;
QueryRun qRun;
CustInvoiceTrans custInvoiceTrans;
CustInvoiceJour custInvoiceJour;
SalesLine salesLine;
SalesTable salesTable;
MainAccount mAccount;
DimensionAttributeValueCombination dimAttrCombination;
//SalesTable
datasource = query.addDataSource(tableNum(SalesTable));
//CustInvoiceJour
datasource = datasource.addDataSource(tableNum(CustInvoiceJour));
datasource.addRange(fieldnum(custInvoiceJour,SalesId)).value("=FRA1-000134");//FRA1-000134
//datasource.addRange(fieldnum(GENERALJOURNALENTRY,DOCUMENTDATE)).value(queryRange(4\5\2016,4\5\2016));
//custInvoiceTrans
datasource = datasource.addDataSource(tableNum(CustInvoiceTrans));
//SalesLine
datasource = datasource.addDataSource(tableNum(SalesLine));
datasource.addLink(fieldNum(custInvoiceTrans,SalesId), fieldNum(SalesLine, SalesId));
//datasource.addLink(fieldNum(custInvoiceTrans, LineNum), fieldNum(SalesLine,LineNum));
datasource.addRange(fieldnum(SalesLine,SalesStatus)).value(enum2str(SalesStatus::Invoiced));
datasource.addRange(fieldnum(SalesLine,SalesStatus)).value(enum2str(SalesStatus::Delivered));
//DimensionAttributeValueCombination
datasource = datasource.addDataSource(tableNum(DimensionAttributeValueCombination));
so where i can get a ledgerDimension that have the some value of generaljournalaccountEntry
