Thanks a lot for your link . it was very helpful for me
but , After Post the packing & Invoice
regarding the last step [settelment]
i failed to select the shipment number on the daily journal line for Transaction type field = Settlement
did you why i couldn’t find it works as described below ***************************************************************************** Make a payment for the invoice
After the purchase order is invoiced, you can make the payment and settle the accounts. The payment for the letter of credit must be equal to the amount due minus the margin amount because the margin amount is already collected by the bank. The payment must be within the tolerance limit for the letter of credit.
Click General ledger > Journals > General journal.
Press CTRL+N to create a new journal.
In the Name field, select a daily journal, and then click Lines to open the Journal voucher form.
Enter the required information. Click the Payment tab, and then in the Transaction type field, select Settlement. In the Letter of credit / import collection and Shipment number fields, select the bank document number associated with the letter of credit and the shipment number.
Click Post > Post to post the journal. After the settlement invoice is posted, the letter of credit status is set as Closed.
Instead you can go to Payment journal > enter to lines select the Vendor and then Functions Button > select Settlement. this will give you all invoices not yet settled for that Vendor select the one the LC (you can filter invoices list by changing the combo from type All to Letter of credit)
Select the invoice(s) and confirm, this will take you back to the voucher line add the offset bank account and the amount. then post !
I am also facing this problem in AX2012 r3, while i trying to pay it through AP, settlement window is not showing the margin transaction, resulting, the payment is proceed without deduction of margin.
