HI,
I am working on Generation of checks using Ax, I have 2 Queries:::
Is this Feature check printing re-usable in Ax??
Why do VOID appear after printning the check???
Please post your solutions …
Thank You.
HI,
Thank You.
Reusable meaning print the same cheque more than once?
VOID means it is not a proper cheque, so it cannot be cashed, the sort of control that would be placed on a test print.
I’m working on cheque printing. 1st 20 cheques are printing properly, after that it is giving alignment issue. But first 20 cheques are fine. Any idea?
Is there any setup available to set some setting for specified no of cheques like that ?after that alignment different like that ?
