hi i’ve created a new table called classtecnic with 2 field idtecnic(extendeddatatype) and number.
in the M_ASDstatisticaldataform i’ve created a new tab where you can see the two field.
I want to:
when i change the idtecnic the value of number change with the value of classtecnic number.
for example:
code ABC number 6(classtecnic)
code BBC number 3(classtecnic)
select ABC number 6 then i change the code to BBC and number value = 3 (M_ASDstatisticaldataform)
it’s possible?!
Someone can help me please?
thank you very much
