Regulatory Control
Hello,
I am trying to sell an Item but on packing slip, the system shows me the Error that the Item is under Regulatory control.
On going to the Item master for the ITem it is found that the Regulatory check box for the Item is non editable and checked. I also tried to remove the Counting journals which might have locked the ITem, but none of that seems to be working.
Pls let me know if I may be missing some set up in the same.
Sneha.
Hit the manage stock ribbon bar on the released product, there is a Compliance section and you define the regulated product setup in there. That is the control that sets the non-editable tick box you are trying to alter
What is the use of the above functionality ?
This will do a better job of explain regulated, restricted, reported and safety data sheet (all the compliance elements) than I could:
http://blogs.msdn.com/b/axmfg/archive/2012/08/11/managing-compliance-with-process-manufacturing-in-dynamics-ax2012.aspx
