RegisterRequiresControlState Error on EP Form
As I am working on Eneterprise Portal in AX 2009.
As I am applying filter on Project Name I got an error like RegisterRequiresControlState Can only be called before and during Pre-Render. How can I solve this problem. AS I find the solution for this problem in ASP.NET website as per below link. www.sitefinity.com/…/registerrequirescontrolstate_error_workaround.aspx But How can I apply this solution to Enterprise Portal in AX 2009.
Thanks in advance.
Janak
I have solve this problem.
Actually in my form AxGridView Control has been used.
In that AxGridView Property I have disable the AllowPaging property set to FALSE.
Now I have change the same property to TRUE and it will work fine.
Janak
