Regarding upgrading Customzied codeunit written in local language
Hi All.
Currently my client is on 3.70 version and using some customized codeunits which are written in some Latin local language. Kindly let me know the procedure and impact of these codeunits, If I upgrade the database from version 3.70 to NAV2009.
Thanks in advance.
Hi Dillaa,
You should really upgrade everything. Especially customized codeunits. If they are written in a language you don’t understand, then find someone who can help you to translate it. You should also check out this article about how to upgrade Navision.
