I have to add two field on sales header and sales line and the data should flow on the Shipment Header & Line and also on Sales Invoice Header & Line.How it can be done?
Hi Naveen,
May I know what did you try to achieve your requirement?
you should also mention what did you try and where did you struct also in your post
Hi Sir,
I have added two field on sales header & two field on sales line and enter some data,how to show these data on shipment header and shipment line also invoice header and invoice line??
You just need to add the same fields with same ID and Data type in Shipment header and Invoice header tables…
