While am posting Item journal lines suddenly my server restarted…In that case do i need to post again after server restarted or not??
And after posting which table will effect?
Hi Vishnu,
Go to Item Ledger Entries. There you can see the posted Lines
Hasitha Jayasuriya
Hi Hasitha,
Thanks for reply and What to do in first case?
Is your Journal batch still populated? If so, then yes you need to post again. If not, then it should be posted. Review the appropriate register to verify.
HI Babrown,
Thanks a lot…and if posted can we change the data in table level ?? if any wrongly entered.
As a general rule you would never change financial data at the table level. You would simply post adjusting journals to correct.
