Hi guys ,
When we write AX SQL statement with fields which we need then how table buffer will react in that case, I mean if i am selecting fields AccountNum, BankAccount from CustTable and making an joing with custTrans on AccountNum field then how table buffer will react or what values they will fetch, That is sure that table buffers will not fetch all the fields from table but i have seen that somewhere in ax standard code that there are selecting some fields but condition is applying on other fields those are not part of selection. Does it mean that after specifying fields also buffer is having all the fields.
