regarding new line generation
In my project, after clicking the check box one new line is generated using table.insert() coding.
that check box is one of the field in my form.
new line must fetch some records from the previous line.
new line and previous lines are same form.
how can i fetch the record from the previous line?
smiley
its a simple syntax you can find in developer help
ttsbegin;
select Firstonly Reverse ;
.field1 = .field1;
.insert();
.update();
ttscommit;
Reverse - used to reverse the whole table
after the reverse firstonly fetch the first record
now you can get the expected result
Hi Axxxapta,
instead of using update, i’m using the research(). now it’s working
thank u
smiley
