Hiii All,
Here i am again facing a problem in Nav 2013 when i run the Page, a error Regarding NAS instance…i attached screenshot for the same here…plz suggest some idea…thanks in advance
Akhil
Hiii All,
Akhil
Hi, I’m not able to see the image (I don’t know if happens only to me), can you post it again?
Hiiii…i am unable to paste image here but the error is like…“There are no NAV server instance available for this database…you must ensure that Nav server instance is running and is configured to use the database before you perform this activity”…Actually i wana run a Page …So how can Create the NAV server instance plz help me out from this problem…thanks in advance…
Kindly check in service which database is running . If it is not your database then change in service and restart the service and check again.
