Hi Guys,
I like to know the reason for the dialog form which are opening at larger size by default. I’m using Ax 2012 R3 version. Just clarify me on this issue. See the attached file for your understanding. Not able to reduce the size of the dialog. Kindly share your thoughts on this.
Zahir
It tries to open a window big enough to show all your content. It even can’t do that and must add a scroll bar. Use tabs, fast tabs, collapsible groups or something like that to remove some fields from display.
It seems you have not used proper EDT’s for defining input fields which are shown in large size. Use proper EDT’s to decrease the size of the text box which will eventually decrease the size of your dialog.
