Regarding DateFormula
hi every one i have small requirement on date formula suppose dataformula as 12D i want only numeric values in date formula is it possible in NAV
Thanks & Regards
Leeport
No, you need to define unit also, D,M,Y etc. for Day, Month & year respectively.
Why do you need this and maybe there is another solution?
Hi Leeport,
This depends on the complexity - if you just need to add/substract days the you can use an integer
e.g.
Lastweek := TODAY -7;
