Regarding BI Error
hi all
I found a error when loging on Business analytics
I am using SQL 2008R2,NAV 2009 SP1,
If any one have idea regarding that kindly let me know
Thanks in advance
Business Analytics
Command=FieldStructure
Error=Request failed
Detail=The operation has failed because of an error in the COM component - unknown error C:\Program Files\Business Analytics\ANTServer\Samples\MOLAP\Sales.cub A share violation has occurred
OK
Could be one of 2 things.
  1. One user is blocking the file in use
  2. You don’t have permission to read the file
What I would do is to log on to the server with an admin account and then check to see if it works. If it works then you should change the permissions for reading the folder.
If it doesn’t work, then restart the server and the file mentioned should be cleared from the violation.
Good luck
