Dear all
I have item table in which I have description 2 for item .
Now i would like to add description 2 (from item table ) in item ledger entry .
Regards
Shubham
Dear all
Regards
Shubham
You can add a flow field to calculate the Description 2 in ILE based on Item No.
If you want to do it ia code, then check how Description field is inserted in ILE. (but it will not update for past entries.)
Hi Shubham,
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
