Can i know while postng an entry in navision in how many tables it will effect???
That depends upon what you are posting.
Which version are you using?
If you are using classic then you can activate Code Coverage and check how many tables/code it executed.
iam using the classic n can u tell me how can we activate code coverage for checking for how many tables it had been updated
Run Code Coverage tool from Tools–>Debugger–>Code Coverage
Click Start
Minimize the Code Coverage Form
Post the entry you want to post
Open the Code Coverage Page
Click Stop button
Click Code button
You can see all objects which are hit by your posting
Thanks sir its working
Welcome.
Please verify the post which solved your problem…
Depends upon what you are posting
Not really. If you’re using Code Coverage then it will work for all type of postings.
