refrsh form or grid in ax
hi all
i have a form and a grid that i want to refresh data in grid when i click in the button
i use update command in this button
thanks
choose the one which applies best for your case:
http://kashperuk.blogspot.ch/2010/03/tutorial-reread-refresh-research.html
According to your description, it seems that this is the combination you need:
YOURTABLE_DS.reread(); // reread fresh data from database
YOURTABLE_DS.refresh(): // then redraw form with this fresh data
Janis
You can also use the following code : yourForm_ds.research(true);
Thomas
Hi jm,
Thomas’ post has proven successful for me in the past and it’s only one line of code. Here is a blog post on the differences from the datasource reread, refresh, and research. It explained a lot about the differences for me.
http://kashperuk.blogspot.com/2010/03/tutorial-reread-refresh-research.html
Bob
hi Thomas
thanks for your syntax
it work CORRECT
