i m updating the one from data from the other form.my data is in the current form is getting updated but cursor in the grid is going to the first record.it not pointing to the same record which i had updated just now.for the ex i have 5 record in the grid and currently my cursor is in 3rd record then i clicking on the one menu item button which is opening one more form there i entering some data which should get update in my first from 3rd record and cursor also should be in the 3rd record.but in my case data is getting updated but cursor is going to the first record.i had used the execute query in my second form to update the record in the first form.
I think what you want is to update your caller. It’s hard to understand your question exactly.
Look at the method on the SalesTable form called “doRefresh”, and then look at the form InventOnHandReserve method called “callerRefresh”. They do “caller.doRefresh”, which actually runs the method on the SalesTable, even though intellisense doesn’t pick up the method because it’s an abstract type.
