Refresh the data of form
On SalesTable form i have a menu button “Menu1”
This button is used to open a form B which would insert some data in
SalesTable Table at click of OK command button. Along with the ‘create new(FormB)’ form one more form also opens which shows the newly created record.
At the same time my SalesTable form is also open.
Now i want SalesTable form to show the newly inserted record as soon as i create the record.
I have refered the previous posts discussing how to refresh a parent form. The solution suggested there does not work for my case.
I just want my SalesTable form to be refreshed when i clicked on the OK button of form B.
Prajakta
In the click method of ur menuitem after super() write
SalesTable_ds.reread() ;
SalesTable_ds.refresh() ;
SalesTable_ds.exequteQuery() ;
and where you r updating the salesTable in that forms method write salesTable.reread(); (after updation)
Create a button auto refresh
void clicked()
SalesTable cacheRec;
int i;
super();
i= 1 * 60 * 1000; // Refresh every minute
cacheRec = Salestable::find(Salestable.RecId);
Salestable _ds.research(true);
Salestable _ds.refresh();
Salestable_ds.findRecord(i);
Try this if u r able to do it. I hope it will help
Hii,
You need to use args class to refresh sales form . catch args object of sales form in your form and call execute query method.
Thank you all for your replies…!!
HI Paji,
Try this it will work.
On child form
in class declaration method
Formdatasource callingformdatasource;
in init method of child form
callingformdatasource = element.args().record().datasource();
then after whatever operation you want to refresh the parent form data in that write following code.
callingformdatasource.executeQuery();
callingformdatasource.refresh();
Hope this will be helpfull to you.
Thnx,
Kirtan Dave
